Charles gettys
Thread starter- Joined
- Jul 1, 2016
- 1
This motor ran hot and I replaced Pistons, rings and it ran great for about three hours and then started running extremely rough with backfires. It will idle but will not throttle up unless you prime it heavily then will die backdown while back firing. I've cleaned the carb, new fuel pump, new lines, new plugs, thought maybe top cylinder was missing because mag got hot when motor ran hot so it was replaced as well as coil. Motor cranks first pull but refuses to run smoothly with power and will dye when throttled up. I've checked compression 120 psi both cylinders and spark is hot blue. When it backfires it seems af if the timing is bad because it really slows the motor down. It will backfire every few seconds when trying to throttle up and will cause it to quit, it will idle though roughly and still backfires some but it will usually keep running. Any body got any ideas as what to do next??? What does the other electrical component under the flywheel do that appears to be sensing the flywheel position? Also what is the purpose ot the other electrical component on the other side of the engine that has wires running to the coils? Look forward to your help!
