1984 15HP Johnson tiler handle
mltessier
Working on 15HP Johnson from 1984. There is a lot of play in the throttle on the tiler handle. It moves a lot before it gives it gas. I've checked the teeth on the gears and they are all there. Are there any adjustments I can make? It is also hard to turn the handle. Thanks for your expert help!!
kbait
Google: leeroy’s ramblings
click on OMC 9.9/15
read away! He describes some causes/fixes for your issue, and is a great source of info on your motor.
Good luck!
