1984 115hp Mariner very smokey on startup
Big J73
HI
Just got myself a winter project its a 1985 fletcher 160 with a 1984Mariner 115hp (6cy). Engine will only start with lot of throttel and then runs very smokey when you cut it back.
J
arsenalpsu
Re: 1984 115hp Mariner very smokey on startup
First off get a manual, it will help answer a lot of your questions. There are a lot of people here that can help but you need to state your problem with an actual question.
You probably have the engine running too rich if the smoke is excessive. This is a 2 stroke so it's going to smoke on muffs. Does it stall? You could also be burning off de-carb oil from when it was stored. Have you run at WOT in a lake yet?
Chris1956
Hey J, that motor will smoke a lot if there is a tear in the fuel pump diaghram. They also bog and load up at idle and take a while to clear up as you throttle up.
You might rebuild the fuel pump to remedy this issue.
Big J73
Hi Guys
I have ordered a manual today. I hope to get to work on it this weekend so i will check the diaghrim as well. i am a bit of a novice with boats so i will need your help.
regards
J
CharlieZulu
Why wil it smoke on muffs? Waht's the difference?
Chris1956
Charlie, The motor will not smoke more or less on the flusher device. It will look like more smoke, since none is buried in the water.
CharlieZulu
That makes sense -- I was referring to the comment above:
"This is a 2 stroke so it's going to smoke on muffs"
I guess really it means "you will see more smoke on muffs because the motor is out of the water"
Right?
