1983 V4 Evinrude. E115TLCTE
C_Curran
How to hook up a rpm gauge directly to the motor, I need step by step instructions if possible
tramsdell
Banned
Like a tach for your dash? Or a diagnostic/tuning temp setup? Easiest would be an induction wire around a spark plug cable. Best would be splicing into the harness.
C_Curran
A tach for my dash, what is the process for splicing into my harness at the dash, which wires to splice into and what wire goes to the guage?
F_R
Honorary Supreme Mariner
There should be a grey wire in the cable leading to the control or dash, whichever. That grey wire is the tach signal wire. There should also be a black wire, probably grounding the control. The black wire is also used as the ground wire for the tach. Wire gauge really isn't all that important. Set your tach to 6 pulses (12 poles).
If your tach is illluminated, the light wires connect to the boat's running lights.
C_Curran
Ok also on my tach is a 12v stud, which wire hooks here? THE main red wire from the harness? Also thanks so much for your help.
F_R
Pick up the 12V source from one of the purple wires. That way the tach is "ON" only when the key is turned on (as when running).
