Re: 1983 OMC stringer trim diagrams
what wires?
The two wires going into the motor don't reference ground.
They should read open (more than 1000 ohms) in reference to ground.
But that's not much of a valid test.
It's a bidirectional DC motor.
You could read the armature resistance if you measure green to blue. I don't know what's normal there though... maybe 5 or 10 ohms...
again - not a valid test
An ohmmeter doesn't really have any function in testing that system. It needs to be tested with current flowing (i.e. voltage drop testing)
Those 12V CD motors are simple to take apart and clean the rotor bars and check the brushes. If you haven't had brush ends off motors before, you can take it to a motor shop - they will clean it up - even a vacuum cleaner place can do it real easy.
If rapping lightly on the side of the motor with a wrench makes it work, that's a good sign that the commutator bars need to be dressed.
I just use a strip of emery paper, and then use a seal pick to give a nice score down each separation.
p.s.- I don't think you need to disturb the hydraulics to remove the motor - it should come up and off leaving the reservoir and pump in place..(I *think*)
