1983 Mercury 80hp power head removal help !!!
basstracker1970
Can anyone please tell me how to get the power head off. I have all the bolts or nuts removed it is just stuck. I dont know if its the bolts or the gasket but it wont budge. Thank you in advance for any help you guys can give me....
PS: This is a 1983 4-cylinder 80hp sn= 6234303
jimdd810
Re: 1983 Mercury 80hp power head removal help !!!
Usually they need a little persuasion. Get a leather faced hammer and hit in a place that wont break. There is a gasket with gasket sealer mounting that motor.
Did you already drop the gearcase? That will make it easier to rock it loose. Some of those inline motors have 2 nuts under the very front of the motor, near the steering arm. The nuts won't even come off the studs until the powerhead is lifted a bit.
basstracker1970
Ok guys I got it off pretty easy after reading one thread on here where they used the nuts threaded back on and placed washers under it and then trurned the nut working it back off to make like a jacking deal. It worked awesome and my lower unit is still on. That idea is the way to go It pushed the block straight up and I just bear hugged it and pulled it off. Thanks alot for all the ideas.
Great. Now do yourself a favor and drop the gearcase. If you leave the gearcase on, and go to reinstall the powerhead in that fashion, you will need to line up the driveshaft splines, while lowering the powerhead onto the midsection. You will likey strip the end of the crank.....
basstracker1970
Ok thanks for all the tips. I have the intake removed now and all the connecting rod caps but I cant get the reed cages to budge. What is the trick to getting them out so I can remove the crank. I dont want to rush and damage anything. Thank you in advance.....
k dogg
the reed blocks have a dowel pin that align them in place
i get 2 flat blade screwdrivers and lightly pry up on them from both sides at the same time
