1983 merCruiser 3.0 4 cylinder.
Austin9398
I did a compression test and I found that I have 80 psi on three cylinders and 60 on the other the motor runs fine but want to know if the right or not
Austin9398
Have a weird noise coming from my 1983 merCruiser 3.0 4 cylinder kinda sounds like sucking air or something
Scott06
I pulled all the plugs out then put the tester on the first cylinder then fired over 4 times the went down the line
Suspect your gauge is off below 100 is normally A dead cylinder smoking like hell and tons of blow by.
if it runs good why did u do the compression check? Try with another tester
engine was up to temp ?
1985 Century Mustang
Can you take a video and post it? If you have a YouTube account you can take a video, post it to YouTube, and post the link. Getting a YouTube account is easy.
The GM 3.0 should be about 140-150 psi for a new motor as that is the published spec for cranking pressure.
As Scott said, anything below 100 is usually a dead cylinder
Austin9398
The temp was good oil pressure good it’s making kind of a hissing noise and that was the first thing I thought to do
My guess: Sounds like you have a compression leak in the engine, not a vacuum leak. Suggestion: Go on YouTube and search videos for your same issue/sound/noise, see what you can come up with. Read all the comments if you find one similiar to yours. That's how I fixed my boat. I had a knocking noise by my flywheel. Some guy posted the same video, on YT. So it put me in the area that needed to be addressed. I pulled my engine and found a loose flywheel coupler. YouTube is an amazing animal.
My issue:
His issue: Almost the same sound.
