1983 Mercruiser 120 outdrive oil filter
madmans
What car type filter do you guys use on this engine? Also where would I buy a fuel sghut off switch for a inline shut off thats reliable? And do you run 30 weight oil in these engines or will a good 15-40 delo 4000 supreme be OK??? Thanx Mike
Re: 1983 Mercruiser 120 outdrive oil filter
Ayuh,.... The oil filter for the motor is the standard Chevy filter, same as the SBCs, comes in several lengths...
Delo is Good oil,....
'n Why do ya need/ want a fuel shut-off,..??
