1983 Merc L6 cyl 2 and 3 no spark
whoswho
I started up my motor last week and noticed it running rough so I did a spark check and confirmed that cylinder 2 and 3 are not getting spark. I have a service manual but there isn't a lot of information about my particular engine since it covers many sizes and models. Its more of a general manual with just the basics. There is a chart of what the resistance in the coils should be and I measured that to be .2 to .3 ohms on each coil (there are six coils). I'm am assuming that the Rx1 ohm scale is multiplied with the .02-.04 scale reading, but 1 x anything is still anything so its weird that I am getting .2-.3 when I should get .02-.04. Unless I move the decimal place over one then that would give me the correct reading on each coil. I will attach the chart for your reference then you can correct me if I am wrong. I am new to outboard repair:(
Compression also checked out to be good but the borrowed tester didn't hold pressure well so I can't give an exact number. Now I want to check the switch box the manual only covers the stator, trigger, and coils. How do I check the switch box to see why one cylinder per box is not firing?
P.S. I cleaned the carbs and they looked just fine so it is not fuel, and the wires don't have broken shielding!!
Thanks
M
Maxz695
Guest
Re: 1983 Merc L6 cyl 2 and 3 no spark
Not a fact and there are tests to confirm this but either 2 coils went bad (I doubt) 2 plugs wet the bed ( Not Likely) the switchbox ix shot (A good possibility) trigger sends 1 single I beleive the switchbox then sends the other singnal to the other cylinder or cylinders.(This has to be confirmed not sure). therefore it is likely it may be the switchbox
whoswho
I see. The coils all read the same resistance from positive to ground terminals so I am assuming that they are okay. The plugs may need to be replaced since they haven't been done so for a couple years but I probably put only thirty hours on the engine anyway. What are the procedures to check the switch boxes?
M
Maxz695
Guest
You should get a manual for your engine if you intend on keeping it. There should be someone who can help you in the proceedure. Keep in mind that yearly maintenance (The act of maintaining or the state of being maintained. 2. The work of keeping something in proper condition; upkeep.) will definitly improve you engine condition. Your engine will only treat you as good as you do it. good luck
whoswho
Thanks Faztbullet.. I will give it a try and see what happens.
whoswho
I am still waiting to hear if I am reading the resistance in the coils wrong or not.
whoswho
Here are the results after doing a resistance check on the stator, trigger and coils... they are all within range. I checked the DVA on the switch boxes and the voltage fluctuates like crazy. Also when the engine was cold only two cylinders, 4,5, were firing. cylinder 1,2,3,6 had no spark. When the engine was warm cylinder 1, 6 came back online. Would that be a symptom of the switch box? And would the fluctuating voltage also be a symptom of the switch boxes too?
daveswaves
Ensign
I,m going to suggest that you double check the forgotten electrical path.....ground. Under each coil is a bare braided wire that connects the negative of the coil to the aluminum mounting plate (a poor system imho). The aluminum plate must be properly grounded to the block, loose bolts or missing ground strap are problematic. The stator must also be well grounded to the block, there are two types of replacement stators, some have an additional ground wire some just ground through physical contact. They must connect to bare metal. The fact that things start coming back to life after it has warmed up suggests a loose ground that gets tighter as the metal expands from heat. Also double check that the white bias wire is connected between the two switchboxes and that the wire itself has continuity. There should be ground straps from each switch box to the mounting plate.
whoswho
Thanks daveswaves, I did as you suggested with the coils. Indeed under each one are two braided wires sandwiched between each coil and the aluminum mounting plate. The wires were quite embedded into the rubber casing so I scuffed the aluminum plate to remove some of the surface oxides and repositioned the wires under the coils with some dielectric grease to keep the aluminum from oxidizing again. There were some interesting noises though. When I removed the upper coil pack coil #2 sounded as though the ferrite core was grinding against something. Is that common?
daveswaves
Ensign
I sounds like the ferrite core is broken so instead of a single core, magnetically you have multiple cores. That can create a weak spark. On the engine rebuild I just finished there were 3 coils with broken ferrite. I swapped them out with new(used) coils. To the best of my knowledge you cannot buy the ferrite separately. It is common to find this, however, there are likely hundreds of engines out there with cracked ferrite that are running just fine. I think your problem lies elsewhere, the cracked ferrite would exacerbate the problem.
whoswho
I replaced the power packs and now she runs great!!!!
Thanks everyone.
cr2k
The test for the power packs is, after you have checked everything else it has to be the power packs (switch boxes).
aussieflash
Well done.Same happened to mine.4 would run cold then all six when warm.replaced both switch boxes and the trigger.Make sure the new boxes are well grounded or you'll be back to the shop.
