illinoisbassfishin
Thread starter- Joined
- Jun 13, 2010
- 49
I am new to this forum and this is my first post. I have an 83 Mariner 115 inline v-6 outboard on my ranger 330v. I recently just bought this boat and got a really good price on it and it is really good shape but I'm having the motor problems.
1st problem is the first time you start it up you can crank and crank and it won't start at all, but if you give it a quick shot of starting flluid it fires right up and once it fires it idles perfectly and sounds really good when it is idling. If you leave the motor shut off and not running for a period of time up to 30 minutes or more it won't start again unless you use the starting fluid then once again it is fine.
2nd problem is whenever you take off on hole shot and you floor the motor it will bog down and die, but if you accelerate really really slow to about half throttle then floor it will take right off and run perfect down the lake at about 45-50 mph. This problems is included when you trailer the boat. When you give it gas to push itself up on the trailer it will bog down and die as well.
I just bought this boat off an old man and you can tell he took really really good care of it. He told me that the last time he ran it was last October and it still had about a half tank of pre mix gas and oil in it that has been sitting since October. We topped the fuel off and added oil and a can of sea foam thinking that would help clean the carbs out and get it back up and going. We have almost ran all of that gas out completely with only about 3 gallons left in the tank and it hasn't came out of it yet. Tomorrow we are going to look into seeing how hard it will be to take the carbs off the motor and clean all of them really good and see if maybe there is a bad diaphragm or a needle or something. Also we changed out all the spark plugs yesterday before we took it out and that didn't help it out at all. Besides cleaning out all of the carbs does anyone else have any advice at all as to what else the problem could be? Any help would be greatly appreciated. Thank you very much.
