Re: 1983 johnson v4 90hp compression
It depends on what heads and gaskets are on it. As long as the difference is not greater than 15 lbs (not %) from high to low, it should be OK. <br /><br />If it does vary from side to side look at the 6 digit number on each head. A matching set (uncut) will be one number off from each other with the port side being the lower number.<br /><br />Do a compression test and then a decarb job. Retake compression to compare.<br /><br />Good luck!
