1983 Johnson 75hp sputtering.
DWP
pretty cut and dry, I had all 3 carbs rebuilt, link and sync, checked all fuel lines for pin holes etc, at idle on muffs the motor kinda spits, just like a single sputter, not all the time and not in a cycle, random sputters from time to time. It seems to go away if i advance the timing a bit but at that point the idle feels too high?
perhaps i need to link and sync again?
**edit update, it was a bad coil, fixed the.problem, onto.the.next.problem...***
