1983 Johnson 60HP - Impeller
Liam
I don't have the book and need to replace the impellar. Can any of you good souls out there tell me how?<br /><br />Much Thanks,<br /><br />Liam
Solittle
Re: 1983 Johnson 60HP - Impeller
Yep. Go to the public library in your area and look in the reference section for a shop manual. Basically you drop the lower unit, pull the water pump cover, repalce the impeller & button it back up.
hondon
If you don't have power tilt you will need to be mindfull of the reverse lock cam thingy.That seems to really frustrate some rookies.Get the book.
Liam
Thank you all. As you mention - the job may have some hang-ups - off to the bookstore I go!<br /><br />Thanks again,<br /><br />Liam
