Mullerhawk
- Aug 2, 2011
- 37
Hi,
Yesterday I bought a 4.40m long boat (V-bottom that weights about 200KG) with a 1983 (I think - could not make out
The exact model) 35HP Johnson Seahorse with pull start, long rig and remote throttle (looks like this:
http://www.youtube.com/watch?v=8OxnGMghZwI)
When test driving the boat and starting I made sure it was not pre-heated but dead cold. It started right away with
Some choke (2n pull) and idled really nice without excessive smoking or strange noises. When pulling out from the harbor and hitting the gas it kind of delivered power a bit slow. And at full speed it feels like it's not revving as much as it should. I would describe it as missing out on power. At full throttle the engine sounds, feels and runs good. But it's lacking power. The boat only went about 16-17knots (the boat should do about 23knots with a 30HP, and probably around 25-25 with the 35HP).
But the boat was in really nice shape, and the engine ran smooth so I bought it anyway.
My first impression was that the boat maybe should have had a short rigged engine to start with. But that would not explain the loss of about 10knots in top speed. I also checked the propeller and it's in really nice shape (new last year). The sparkplugs are new; it's a CDI engine with power pack so there is no ignition to fool around with. Another thought was that the throttle cable did not open the carb fully. But after checking under the cowling it was.
So, now the question is what could cause this the lack of power/revs and still have the engine run smooth overall?
- Could it be worn out pistons/rings?
- Could it be worn out reeds?
- Could it be just a dirty carb?
- Could it be wrong CAM timing (shouldn?t that cause misfiring?)
Thankful for all the tips'n'tricks you can give me. I want this baby running smoothly .
