1983 johnson 200 hp surging problem
four winns 91
I'm new to these posts. I have a 1983 Johnson 200 with a surging problem at wide open throtle. I eliminated a fuel problem from the fuel tank by hooking up an external tank with new fuel bulb. put new fuel pumps and all three carbs were cleaned. when i am at wot, i push the choke in and she takes off. What else can it be. compression at 90 on all cylinders and ignition system checks out ok. Please Help!!!!!!!!!!!!!
emdsapmgr
Re: 1983 johnson 200 hp surging problem
Surging problems at WOT can be a fuel problem. The engine may be taking fuel faster than the pumps can keep up. You have already changed both pumps, usually the first solution. I'd double check to make sure they are the correct ones. The two pumps are different part numbers and the ones for these V6 engines have large hose barbs. You have to run 3/8" hose line (and primer bulb) from the tank to the engine or you will starve it. If you are sure all of this is ok, then check the anti-siphon valve at the tank. I have seen them malfunction (stick) when debris gets stuck in the ball valve-then it affects WOT operation. I'd remove the hose barb fitting at the cowling and on the engine end of the hose. Run the fuel hose through the hole where the fitting was, and then clamp direct to the upper fuel pump. Make sure you don't kink the incoming hose as you connect it to the pump hose barb. Check for any fuel leaks at the hose connections by priming the hose bulb to try to develop pressure to cause a leaks. Any air leak will cause WOT problems. Those year engines may not have had fuel hoses which can handle ethanol. I know my 79 did not. As these hoses age, the ethanol can break them down and bits of the hose can wind up in the carb jets, creating a blockage. You may want to check with Bombardier about whether they need to be replaced. The hoses under the cowling that have bends in them are made special by the factory.
four winns 91
I have changed all of the hoses and removed the connecter at the engine. It is connected directly to the fuel pumps. the 90 degree hose we replaced was just made longer and bent not to create a kink.
emdsapmgr
Sounds like you are taking care of the basic things. Have you compared the jet sizes in the carb with the factory parts list to make sure they are all stock? I'd be careful using bulk hose-esp the lower pump to the fuel mainfold hose.
four winns 91
Sorry for waiting so long to reply. I took the boat to a repair shop and they are still having the problem. They have rebuilt the carbs 6 times and stated that they have eliminated a fuel problem. They stated that the electrical system is working. They changed the three coil packs on the port side and the problem is intermittent. Have put over $500 in parts and still have the same problem. Could it be in the engine or stator?
