1983 johnson 150 hp o/b throttle rod
imallhart
im having problems with adjusting and connecting my throttle rod back after putting in a new impeller in it i got it back in but to only have it go in forward and not reverse , i disconnected it and tried to re-adjust it but cant get it to go back into the hole to screw . how do i know if it's set correctly and what's the easiest way to reconnect the rod back up can anyone help me with this issue thx
Honorary Supreme Mariner
You may have to find a way to move the shift rod fore and aft to get it to line up with the hole.--If you are a novice it may help to remove the bottom carburetor to get it right.
