1983 Force 50hp 2-stroke - ignition coil troubleshooting
TMad1630
I think I have a bad coil. How do I meter it out? What readings should I be seeing? Also, the replacement coils are really expensive. Can I use a newer coil (less $$); will it have the same electrical properties just in a different form factor?
jerryjerry05
To test the coil just swap it with the other one.
Check the points??
Welcome.
