1983 evinrude 150 v6 (e150trlcte). Boggs under a load..
LukeM79
I have been checking and fixing anything I find that needs it but the problem is still here.... please help figure out what I'm over looking
LukeM79
Also. It starts very easy and idles good on the muffs and in the lake. Ive tested everythijng I know how to test and fixed a few things but the problem is still there. Hoping someone can give me something else to try
ondarvr
A list of what you've checked would help give some suggestions.
LukeM79
The compression test was first. At first I thought it was very low but after talking to a mechanic he told me this motor with these heads never had over 85 pounds new. The tests was 64 on 5 cylinders and 61 on the last
LukeM79
I did a spark test to see if it would jump a 7/16 gap and it will on all 6. I've cleaned all 3 carbs. Checked for no leaks or damaged from the pick up in the tank to the carbs. It's all new now. Checked the timing. Set it with the Reeves way on here. Pulled plug wires 1 at a time while runni my. All 6 had an idle change but very slight change of each
LukeM79
2 things I'm wondering about.... #1 the carbs are different. The top and bottom carb is 1 3/8 bore the middle carb us 1 1/4 bore.... would this cause a problem? And why would this be like this? #2 I checked the recirculation valves and 5 of the 6 failed. Soaked them in alcohol over night and didn't help. Could these check valves cause this problem?
Honorary Supreme Mariner
I would pull some bypass covers to inspect pistons and rings.---There are 6 small covers on the side of the block.---Six screws each and cheap gaskets.----Well worth doing !
LukeM79
What exactly will I be looking for if I pull those covers? Cracked ring? Scarred cylinder? The only reason I haven't went to the compression route is it literally starts with the bump of the key... cold or hot. When cold I can start it. Clear it's throat 1 time with the high idle lever and go straight back and it will idle just fine. Those compression numbers would scare me if it was hard to start. Has anyone ever seen one start easy and run fine at idle with low compression?
LukeM79
1983 evinrude 150 v6 (e150trlcte). Bad recirculation valves
Will bad recirculation valves cause a loss of power under a load? My motor bogs under a load. I checked the recirculation valves and found that 5 of the 6 are bad. Could they cause this problem?
LukeM79
1983 evinrude 150 v6 (e150trlcte) carburetors
My outboard has 2 different carbs on it. The top and bottom are 1 3/8 bore and middle is 1 1/4 bore. Is this normal? Would it cause problems?
GA_Boater
Luke - Your three threads have been moved and merged. It also helps to post in the proper forum section and Website Issues is not the place for motor problems. Please keep to one thread if you expect meaningful help.
I would say a desperate novice was working on the motor.------Made it run so it could be sold.----No that is NOT NORMAL !!!
LukeM79
All 3 are jetted the same... would this cause loss of power under a load?
LukeM79
And thank you for moving my post to the right location. I was having a little trouble. I'm new here. I have it figured out now.... hopefully I can figure out this motor now
LukeM79
Can anyone tell me the correct bore size for the carburetors on this motor? I want to replace these with the right ones but can't find the specs on them.
