1983 evinrude 140hp starter problem. help!
browncajun
i just put in a brand new starter and when i turn the key all it does is spin, does not move up to engage. it spins counter clockwise when i turn the key but when i turn it with my hand it turns clockwise and moves up to engage the fly wheel. what is the problem?
emdsapmgr
Re: 1983 evinrude 140hp starter problem. help!
You may have issues with the main starter cables or solenoid. Validate the starter itself first with a simple test: try jumping it direct with jumper cables to a strong (well-charged) battery.
browncajun
okay thank you. Could it be the solenoid isn't giving it enough power, meaning i need to replace it too?
emdsapmgr
Yes. That starter solenoid is a sealed unit. It has special contacts inside that will transer high starting currents when the key is turned to start. With age, these contacts can get burned. When burned they may not always transfer current well-seemingly causing starter issues-when they aren't. I've also seen them stick closed-with the starter just spinning forever with the key back in the "run" position. Also, make sure the battery cable ends to the starter/block are very clean and shiny. If they oxidize over the years, one or more of the cable ends may not transfer current well. Also not a starter issue.
browncajun
i got it working! Did a load test on the battery and it was bad so it wasnt giving enough power. Thank you for all the advice now i know what to look for if it happens again!!
