1983 Evinrude 115 newbie needs help with controls set up -
1Cerberus4u
Good afternoon everyone!
Newbie here.
Just picked up a 1983 115 VRO (disconnected) with the old white control box and the red plug.
I was able to mount the motor with trim and tilt on the boat, mounted the control box and wired it up.
Everything seems to work fine, (tilt, trim, it starts, idles and the idle controller works)
However, when I shift the motor into "forward", at first it keep stalling but more importantly even it I move the control lever all the way forward the boat (1967 Whaler Nauset) only goes about 5mph, and won't even come up to plane.
The motor seems to be just off idle and does not rev up.
I've checked and the cable controls seem to be adjust right (well when I shift to full forward, the upper cable opens the carb all the way up, so I know its getting full range)
However, I am unclear as to which cable goes to which control on the motor.
Right now the lower cable is attached to the smaller, more inside lever on the motor. Is that right?
Any help would be really apprecaited
Best
Andy
henleyhale
Take the boat out of gear and push the throttle down. The cable that moves is your gas. Hook it to the fuel linkage.
