1983 Capri 1400 Bayliner Wiring
redline04black
Ok, So i am new to boats and new to engines. I have some help on the way but I am hoping to chase down some wiring issues on this boat so i can eliminate that before we start the engine work. I found the wiring diagram and it has been somewhat helpful but I am still confused as ****. Can someone help me with a good place to start? Also I am attaching a photo. Any Idea what this wire should be connected too?
Don S
Re: 1983 Capri 1400 Bayliner Wiring
It's the start slave relay.
You must have a Volvo
I would need a better view of all 4 wires going into the connector to tell you where it goes to. It look like it goes to the starter solenoid, but hard to tell from that angle.
Don S
That wire hooks onto the starter solenoid, the outer most small terminal.
MacPointMan
WOW he is good. I definitely know where to go when I have questions about my boat when I get it in a coupe of weeks.
MacPointMan
redline04black
Don,
Thanks.. It was very helpful. We were able to get all of the other wiring sorted out. The motor cranks but I have no spark. I need to order several parts but I am not sure the best way to get the part numbers so I can shop around. I cant seem to find an engine model as the blue tag seems to be partially removed. I need a new ignition coil, carb rebuild kit, impeller, drive belt, alternator belt. If I send you some pics can you help?
Don S
Post a couple pictures of the complete engine, both sides as much as possible.
It's probably an AQ 125 A or B, lets see if we can't make sure.
