1983 Black Max 150 Not Shifting into Forward
1974Revenge
I can manually (cable disconnected) move the lever into reverse and neutral, but it will not go into forward.
Any ideas?
Thanks!
sschefer
Re: 1983 Black Max 150 Not Shifting into Forward
Is it running when your doing this?
1974Revenge
I have tried it running and not...same result.
When running, it shifts perfect by hand into reverse and neutral though..just wont budge into forward.
sschefer
If the linkage is free from obstruction and the pointer is lining up with the marks on the shift slide that indicate f-n-r then its in the lower unit. Hard to say exactly but a possibility is the clutch dogs are worn on the forward face. Often when that happens you hear a chatter when you try to engage it. It could also be a worn shifter lever cam that's only moving the slide in one direction. Those are just my guesses.
It could be an expensive problem to fix so get a shops opinion before you throw money at it.
1974Revenge
thanks for the reply, I will have a shop give me an estimate in that case.
