1983 bayliner Capri Volvo Penta ignition switch
bbrad9151
I have a 1983 bayliner Capri it keep stalling while full throttle, throw it in Neutral and try to Start and it fires right up Everytime. I'm thinking maybe a bad ignition switch, any help on where to buy a new one to fit would be greatly appreciated , thanks guys
bruceb58
I really doubt it. Jumper it as a test but likely fuel related.
jerryjerry05
Check the tank vent line.
​Check the fuel filter for water?
It really helps if you add the year, hp of the motor
ScottMartzen
Ignition switch is probably the least likely cause. Check fuel system first then distributor/ spark..
