ClockRocket
Thread starter- Joined
- Feb 18, 2012
- 42
Am currently knee deep into the resurrection of this old beast, but am having issues...I did the compression check and all numbers were stellar ranging from 147-155. So I decided to pull the exhaust manifold due to the raw water tank spewing water out of the cap, well one of the bolts to the #4 cylinder broke off and am now going through the joyous task of figuring out how to remove it. I was a little freaked out because their was some corrosion on the inside of the cylinder...well I thought that it was corrosion, but am not sure because of how perfect it looked, also their was a piece towards the back of the motor under where the exhaust manifold is and I am not really sure what it is...here is a pic of the odd cylinder wall, and the copper looking piece that looks like something should be hooked up to it. Also...how should I go about getting that bolt out? One last question...on the manifold where the copper line hooks up to their was a large old next to it..I took the bolt out and it was plugged up, so I unplugged it and blew it out with the air hose...what is that bolt their for? The first pick is of the weird cylinder, the second is of the 1st, which looks more normal to me...and the last is of the piece that im trying to figure out what it is.
