Shorebreak91
Thread starter- Joined
- May 2, 2020
- 29
Well, looks like I might have gunked this up! If you've seen my previous posts, I have an 85hp Chrysler that has been giving me some trouble since I bought it (would bog down and die after 25-30mins WOT). When I took apart and rebuilt the carbs, my first trip out maxed out at 10mph, so I took them apart again and had maybe 10-12mph on the 2nd trip out. This 2nd trip also featured a lovely 500lb water passenger when I forgot to put the plug in the boat and took on quite a bit of water.
Fast forward to now and my boat has been at a mechanic for 4+ weeks while waiting for its turn (only mechanic in the area that would even touch it). I did a recent compression test on the engine and found that it had 120 compression on the top 2 cylinders and now 0 at the bottom. The mechanic recently got to my bought and found out the same. He planned on taking the powerhead off to see if it was something more trivial than a hole in the piston, but he says the bolts were so frozen on the powerhead, it would cost $400+ in labor just to get it off. He thinks I should trash the engine and look for another one (he put a few calls out though I'm not looking to drop more than $1500 given that the boat was only $1K or so). I feel really sick about the idea that I might have caused the denotation in the cylinder (if that is the culprit) due to my re-building of the carbs incorrectly. Not sure if the Chrysler is worth anything to anyone with 2 working cylinders.
