eastcoastitalian
Thread starter- Joined
- Sep 29, 2012
- 5
i have a 1983 chrysler 55hp,2 carb set up, with the prestolite cd ignition and i had a few timing question i thought someone might know?i just did a rebuild on the engine so i have to redo the timing.the clymer manual says to put the trigger in the full retard position while cranking with a timing light aimed at the marks and it should be at 2 degrees btdc.question,would full retard be meaning to loosen the the idle bolt on the tower and turn the trigger back as far as possible?also i'm assuming the timing on this engine would be performed with the spark plugs in,the same as you would a car engine?thanks in advance for any help in clearing this up.
