1983 +/- 50hp Thunderbolt, needing info on a Power Trim unit
Bandchaser
I have picked up a new rig, and the outboard does not have a power trim unit. The serial # is 7201552. I believe its a 1983-86 model motor, a mercury thunderbolt 3 cyl.
After doing some research, I an not positively sure on what kind it did have or what would fit it. Would it be a 2 or 3 wire unit, single, dual or 3 ram set up???????
This site has helped me in so many ways in the past with different motors, but just never registered. Any and all help is welcomed. Thank you in advance.
Brian
Bandchaser
Re: 1983 +/- 50hp Thunderbolt, needing info on a Power Trim unit
Thank you for the reply. I did happen to take a look at these listings, but I have a question. Can I pick up a complete trim unit (used)?? If so, what infor might I need so that I can get the right part the first time.
