1983 50hp mercury fuel starving
Donnieha
I have a 1983 mercury 50hp 2-cycle. I have cleaned the carbs, replaced fuel lines, replaced primer bulb, replaced diaphram, and gaskets. But it seems to be starved for gas. It will not get full speed unless I keep priming the bulb.once the primed gas is gone it will only go 1/4 of speed.any suggestions?
M
Maxz695
Guest
Re: 1983 50hp mercury fuel starving
rebuild the fuel pump!!
Faztbullet
The fuel pumps are on the sides of each carb, when you cleaned carbs did you install the correct carb kit? There are 2 different diaphram kits depending on brand of carb(walbro or tillitson) and they look nearly alike. Also did you install the carb mounting gasket correctly as it has a small hole in it so crankcase pressure operates the fuel pump on carb.
Donnieha
Well i am a new owner, first boat. So when i went to get the diaphram kit, I just asked the sales person and he brought me the gaskets and all but after doing some research and taking the carb off and replacing it, I noticed he didn' t actually give me the diaphram. So I am pissed... I'll go back probably thrusday. ... I'm learning,,, I hope?
