1983 50 HP Evinrude, turns wont start.
cidporter
Hello, this is the first boat I have ever purchased its in decent condition. It came with an 1983 50 HP Evinrude that i had already purchased and reinstalled a new wiring harness that i got(was an absolute need since the old was completely rotted). Side note boat has not been started in 8 years but did start 8 years ago, the owner was an elderly man who could not get in it anymore. Bought a new battery whole nine yards. when i turn the key didnt crank at first but does now beautifully but wont start. Checked to see if its getting a spark and gas and it is. Also bought new sparks before i even tried starting it. The only concern i have with the wire harness i bought is that all but two wires are the same color. i didnt take out the old one until until i had the new one but where there used to be a black wire i replaced with the gray wire that was on the harness and what seemed to be a white wire (honestly cannot tell with the color is) is now replaced with a red wire. If i switch the wires is there a possibility it could damage the motor and i just took a lucky guess the first time? The website i got the wiring from said it was part of the ignition. If you look at the link its the exploded view of the ignition system. i replaced #34 (its the entire piece). Would greatly appreciate any help or advice thank you!
Joe Reeves
You need to obtain a wiring diagram and keep the wiring colors uniform... as they should be. Changing from one color to another for economic reasons will lead to confusion and disaster.
Remove spark plugs.... check the compression (what are the readings?)... check the spark that should jump a 7/16" air gap with a strong blue lightning like flame, a real SNAP!
cidporter
Thank you Joe for your response after farther tinkering i discovered the wiring was in the correct place and either way wouldnt effect the starter because it ended being for a tachometer which i dont even have. this morning i bought and replaced the starter solenoid. It started second try!
I let it ran for a while to warm it up and then the starter gave a loud buzzing noise and then shut the engine off (over heat warning i assume).
Another question i have is how important is the spout that lets water run through the engine to keep it cool. instead of cleaning it real quick i just removed it from the hose. does the spout restrict water to help keep water in the engine?
Joe Reeves
There is no spout that lets water run through the engine.... I think you're speaking of the water tell tale, a device to simply give you an idea how strong the pump is pushing the water.
The warning horn sounds before the engine is hot enough to do any damage, but that doesn't atop the engine.
cidporter
To finish this post so other on lookers can learn from my experience and research. For a short period of time it is okay to use the engine muffs and the hose if you are working on a motor to see if it runs. If you get it running, great. Now run it in a barrel (garbage can etc) to see how well the impeller and entire water pump works together to cool your engine.
The hose will force water through your tell tale (water tube in your motor for those unfamiliar with the parts). Therefore you may or may not know if you're water pump or impeller needs to be replaced.
My advice is to just replace anything that has a good chance of being seized after not being used for years
