1983 35 HP Johnson Model J35ELCTS dead miss under load
J Walter
Motor runs fine in a barrel at home. As soon as I get it on the water under load, it has a dead miss that makes the engine jump about every 20 seconds no matter what the speed.than it continues to run fine until the next miss.also when I give it full throttle it will take off fine but then shut down like it is out of fuel.If I back off it will run fine again except for that dead miss.Don't know if that's related or not.
tomhath
Master Chief Petty Officer
The miss is probably either running out of fuel or a lean sneeze. Sounds like a fuel restriction or air leak in the gas line somewhere. Might also be a weak fuel pump. Look at all the fuel lines (ethanol might have caused them to crack or break down inside and clog the carb jets). If the fuel pump looks like it could be 30 years old replace it.
J Walter
Thanks! I'm going to order a carb and fuel pump rebuild kit and try that first. Also check the lines. Thanks again!
