1983 35 horse johnson simple impeller question.
scipper77
I recently picked up a 1983 35 horse Johnson tiller with a pull start. My question is simple. What specifically do I need to do to drop the lower and change the water pump.
I have a '62 fisherman that required removing the power-head, and I have a '72 9.5 that I understand you just drop it and the water tube should stay attached to the top end. I assume the '83 will go like the '72 but I'm not sure when to detach the shift rod.
I have a Seloc manual that came with the motor but I'd rather just wing it for what I anticipate to be a simple job. If it's not simple now would be a great time to let me know before I get myself in trouble.
Daviet
Re: 1983 35 horse johnson simple impeller question.
OK, try this.
Remove the water intake screens, #29.
Remove the shift rod connector, #66 and the shift rod keeper #77. Be careful to note how this is on the shaft, has a taper to it, and don't loose it as it is small.
Remove nut #54 and washer #53.
Remove 4 gear case housing screws #73, and the lower unit should drop down.
I think that should do it.
:: iShopMarine.com ::
scipper77
Thank you, I did not know that you had to remove the screen and do any disassembly before you could pull the leg. I guess I will take the time to review the manual (although I doubt that the Seloc manual will be of much help, it's too general).
F_R
On the contrary, pages 7-55 and 7-56 of Seloc #1302 manual for 1973-89 give detailed instructions on disconnecting the shift rod. And page 7-57 covers putting it back together. Probably more than you will find in the factory manual. Just gotta take the time to sort out what applies to your particular motor.
scipper77
Thanks, F_R. I skimmed the manual last night and saw a lot of diagrams for the lower unit of a 2-4 hp motor.
I regret coming off so negatively, it's just that I have done a few impellers before and didn't want to make a research project out of this. Of course I will end up making a project out of this if I'm already spending time here figuring out if it's safe to just dive in.
