1983 25hp johnson won't go in gear
j_jgarrison@hotmail.com
Still having problems. With the motor running it won't go in gear it just happened all of a sudden while going wide open just wondering where to start, any help will be appreciated
Daviet
Re: 1983 25hp johnson won't go in gear
Check the connector for the shift linkage.
Is there any metal in the lower unit oil?
Will it shift properly if the engine is not running?
jtexas
don't understand...all of a sudden with the motor running wide open, it wouldn't go into gear?
It shouldn't be running wide open in neutral, and you shouldn't try to shift it into gear at that speed. Something will break.
Have you tried shifting it into gear with it running at idle speed?
Or maybe, try to explain exactly what you are doing, and what's happening with the motor when you do it, and the sequence of events that led up to this condition. In the order in which they happened in.
