jwmullins79
Thread starter- Joined
- Feb 22, 2008
- 11
I thank all of those who helped me with my last problem on my little 55hp engine. Now I gotta bigger problem with my 175.
This engine has been sittin up for a few years, and I aquired it for almost nothing. Put a little bit of work into it, and got it runnin. HOWEVER, I have a major problem in the fuel system somewhere. After gettin the engine running, and taking it out for a test run, I quickly found out that that I wasn't getting all the power I should out of this engine. Seemed like it wasn't running on all cylinders. I got it home, took the spark plugs back out of it, and checked all cylinders for compression again. Compression is good. Noticed though that the top right cylinder (looking at the engine from the back of it) is dry. Hasn't been getting fuel/oil mixture to this cylinder. All other cylinders and spark plugs have a small oil residue on them, this one is as dry as it can be.
What is my problem here? I'm thinking a clogged jet, or a broken reed valve. Any help would be appriciated.
