1983 15 hp Johnson clunked, overheated, and won't start.
Putz 2
Had been running and idling perfectly for 20 minutes. Went clunk, overheated, and will not start.
Compression is 60 psi in both cylinders. (My 1st time - directions said to disconnect the coil - I did not do that?)
Could be original water pump pooped out?
Honorary Supreme Mariner
Fact ----Outboard motor like that just needs a new impeller about every 5 years.------There is no overheat or shutdown feature on them.----They will run and go ---BOOM---- as you found out.------Remove cylinder head to inspect cylinder walls.
