FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I can make it move if I jump out the relays with a screw driver. No action when I press the buttons on the shifter. Is there a fuse somewhere that I am not aware of??
First make sure key is on as this style will not trim if key is off.If this is ok, check the 5 wire pin harness off the main harness as this is where control box is fed power for trim operation.
I will have to check the harness as the key is on when I attempt to trim the motor. The boat is on the trailer in my driveway when I am trying to raise the motor.
