1982 Mercury 90 HP Choke Question
111torrance111
When pushing in the key to Choke this motor what action should I see by the carburetors?
Motor will not start cold without starting fluid, however after running for a bit it restarts just fine, I'm thinking it might be a choke issue.
Compression is good (Approximately 150 Lbs. each) everything else looks good.
Thanks/Jerry
Chris1956
Honorary Supreme Mariner
Inline six right? There should be two plastic choke plates that close on the top two carbs.
jimmbo
An 82 might not have a Choke, this was the Period when Merc was switching to an Enrichment system
