1982 Mercury 50 HP Trigger Test
82stump
Hello, how do I test the trigger on a 1982 Mercury 50? There's no spark on cylinders 3 and 4. I have tried swapping the coil packs and switching stator wires but the problem remains the same. Will swapping the trigger wires from cylinders 1 to 3 and from 2 to 4 on the switch box verify anything? Thanks in advance for the help!
-Stump
82stump
Swapping the trigger wires at the switch box will help determine if the trigger is faulty. In case anyone else was wondering. I couldn't wait for a response. If someone else tries this method just be sure you do not try to start the engine. I believe it changes the firing order.
-Stump
