kitokamuro
Thread starter- Joined
- Jul 19, 2011
- 36
i was told that when you replace the gear oil, you fill it from the bottom and it vents from the top. is this true? is there a trick to it
thanks
thanks
thanks, can i use 90wt rear end lube?
also, would it be nec. to replace the water pump impellor if i only use it 5 hours max yearly?
