I got his motor for free in great shape, except it needs a stator and trigger, and the flywheel was taken off by the eight bolts and not at the hub so I don't know how to install it for the correct timing, the pointer is still in place,
Also, I see the stator, held on with 2 allen head screws and the trigger but also another component that is held on by 3 Allen screws. it has three metal surfaces facing the inside of the flywheel (magnets) similar to the stator but with two wires connected to the rectifier, both wires are yellow with a red stripe,
What is it and should I test and or replace that also?
Thanks for any help you can give me
