markhoekstra
Thread starter- Joined
- Nov 2, 2008
- 10
I just finished rebuilding both carbs on the 1982 Merc 50hp on my pontoon boat and have a couple of questions about adjustments.
1) I replaced the foam floats with new plastic ones. When I put them in, each sat differently in the carb. One was very high (about 1/2" above the carb bowl gasket) and the other was low. After adjusting both to the 1/4" above the bowl gasket as recommended in the service manual, I put them back int he engine and pumped the fuel ball. Gas started shooting out the front of the top carb (which was also the one that initially sat too high). I adjusted it to around 3/8" above the gasket. This fixed the problem. The engine runs fine now, but will this cause any problems that are not apparent?
2) I am not sure what the proper procedure is to adjust the linkage between the two carbs. The original one cracked so I installed a new one. I put the throttle in neutral, and then tightened the bolt on the lower carb. This way both carbs should have been in the same position since the spring shuts the inner butterfly. Again, the motor seems to run fine at idle and under load, but I want to be sure that the lower carb gets enough fuel (i.e. lubrication) when idling since it's a pontoon boat and I spend a lot of time at slower speeds.
Thanks to everyone else whose posts to this forum got me this far!
