onesubdrvr
Thread starter- Joined
- Jul 28, 2010
- 20
Good morning, and happy thanksgiving!
I am having a problem with my Johnson, and think I've got it narrowed down, but want to make sure
As the title says, it's a 1982 115 (TLCNB115), on a 1992 SeaPro 180CC (center console V hull fishing boat)
Problem: A couple of weeks ago, I was on the water, engine was running fine, on the way back to the boat ramp, engine RPM died down to 2500 (or so). I had been running in the flats that day, and thought I might have sucked up something in the water intake, and attributed it to the SLOW system.
I rebuilt the water pump completely, took it out on the water last weekend, and the same problem, won't go over 2500rpm, regardless of weight setup / distribution, trim / etc. (trying to vary load).
So, I'm thinking it's either a powerpack, or the SLOW system, now I thought I read here that the SLOW system wasn't in use in 82, but I have two temp switches on the cylinder heads(?)
Of course, on the muffs, there is no problem what-so-ever, engine fires right up, and runs smooth. On the water, fires right up, runs smooth, just can't get over 2500.
Any suggestions would be greatly appreciated.
Thanks
Wayne
Thanks
Wayne
