1982 Johnson Carburetor Linkage to air intake pedals
Status
Not open for further replies.
Twillis93
I was rebuilding my carburetors yesterday got it all put together. Then a spring pops off and I have no idea how to connects it back on. It connects to the lower Carburetor close to the throttle roller. The spring attaches both linkages some-how.DSCF2807.jpgDSCF2803.jpgDSCF2806.jpg
That is the spring in question, and my Carburetor links.
The spring manages how much airflow gets through my carburetors.
My outboard is an Johnson 50 horse 1982.
F_R
Honorary Supreme Mariner
Re: 1982 Johnson Carburetor Linkage to air intake pedals
The spring goes on the chokes. It closes them, but allows suction to partially open them when the motor starts. Sorry, I don't have a picture.
Bosunsmate
It attaches to the lower butterfly control arm, and it faces the way you have it. The centre shaft of the butterfly control rod goes through the middle of the spring loop
Bosunsmate
The small end goes down and wraps around the shaft thats below it. As the butterflys are opened the long end of the spring comes down against the front choke mechanism and thus keeps the tension on it
Bosunsmate
Ps its facing the correct way in photo two, not photo one
Twillis93
Thanks guys, I'm not home right now but I think I got it. just in case not, Do you think you could use my photo to show me maybe draw it on there.
Bosunsmate
Im not good at drawing so here is a photo60hp.jpg of it
Bosunsmate
The long end will point forward and hang in mid air until the throttles are opened up far enough under throttle
Twillis93
Ah that makes sense, well thanks for the picture speaks a thousand words. This has been driving me crazy haha.
Balue
Does anyone know what the spring in this thread is called? - I need to order one or I may never get to go fishing again!
GA_Boater
Balue
This thread is almost 3 years old. If you want an answer, start a new thread and identify your motor.
Closed.
Status
