ib18
Thread starter- Joined
- Mar 2, 2013
- 489
I had a blast with my boat for 2.5 months after replacing my mercury 90hp with the Johnson 90hp. Good time don’t last forever.
I took my boat out 2 weeks ago, and started it and ran fine for about 1 mile on the water, shut off the Johnson outboard 90hp engine to drift for fishing. No fish after half an hour, so I started the motor and drove to a second location and fished for half an hour. No fish, so I started it up again without any problem, and drove to a third location and fished for half an hour. I tried to start the motor for the third time, but it won't start. I can hear it crank but it just won't turn over. So, I had to call the tow boat to get me back. I got home and hooked up the water hose and tried to start it up last week but it would not budge.
Started trouble shooting the non-start issue: https://www.youtube.com/watch?v=uekHC8FYr7M
1. Compression test was 120psi for all 4 cylinders – good.
2. I noticed a long fuse that was not fit for the Red fuse holder. The connection in the fuse holder was a bit rusted, so I cleaned it but it still would not start. The fuse is between the key switch plug and the starter solenoid. Fuse is fine just the wrong size for the Red fuse holder.
3. I checked the sparks with a spark tester but no sparks in any of the 4 plugs.
Bummer, I will check kill switch, power pack, stator, etc. More money and time to repair the motor - here we go again.
