1982 Johnson 70 takes off strong then falls on face
safetysam1
my 70 horse Johnson takes off great for a short while then it "loads up" and falls on its face.
It seems to start and idle just fine but under load it just doesn't take off.
I don't think that it is a fuel problem because I use the same tank for my trolling motor and it seems to
run correctly and the fuel is fresh and mixed correctly.
Any help would be great!
Thank-You in advance
Honorary Supreme Mariner
Re: 1982 Johnson 70 takes off strong then falls on face
What happens when an assistant operates the manual fuel pump ??
boobie
What happens if you hit the choke ??
safetysam1
Thanks for the reply,
If I hit the choke it dies right away.
safetysam1
I'm not sure if this got posted but I am not aware of any manual fuel pump.
Would you please inform me of where I can locate it on a 1982 Johnson 70?
Thank-You.
kbait
Manual fuel pump would be a reference to the primer bulb..
emdsapmgr
When the engine bogs on the water next time, try a test. Have a buddy constantly prime the fuel hose bulb. This will force extra fuel into the carbs. If the engine runs normally and ok at WOT as long as you constantly prime the fuel hose bulb, you have a fuel supply issue. Possibly a weak fuel pump, but it could be a bad fuel hose.
