1982 Johnson, 65 hp
ericick2003
I recently purchased this motor from a buddy of mine to replace a very unreliable Mercury. This Johnson, 65 hp, 3 cylinder, 1982 engine starts easily and runs great. I have not tried it on my boat yet, but I've run it on the garden hose and ears for up to 10 minutes at a stretch at a fast idle. Here's the thing that makes me a little nervous... now, although the block seems to run warm and not too hot; water sort of "oozes" out of the two 1/2" thermostat ports at the engine cowling top rear, maybe a drip every 5 seconds... should'nt it come out with more force, like maybe a "sputter" instead of an "ooze"? I had a 115 hp Evinrude and "sputter" is what it used to do... Am I being too much of a nervous eater or what? Is there a way to flush these lines out without too much tear down?
Chinewalker
Re: 1982 Johnson, 65 hp
To my knowledge, Johnson didn't make a 65hp in 1982 - might want to check the model number and get back to us so we can get a better idea of what we're talking about...<br />- Scott
ledgefinder
Ensign
What you describe may actually be a good sign. <br /><br />Expect to see a heavy spray out of those ports when the motor is fully-warmed up & working. But it's not uncommon for there to be little if anything coming out when idling right after a cold start. <br /><br />The thermostat shouldn't open until 145 degrees F. You should be able to hold your fingers on the cylinders for a couple seconds (145 is feels HOT) without burning them. That's ideal - a warm engine idles well, makes more power & wears less than a cold one.<br /><br />If someone pulls the thermostat out (to preclude overheating), then you'll see the spray right away on cold idle.
ericick2003
Actually, after disassembly and inspection... the thermostat was frozen shut, and the water pump was not fully connected (there is a copper feeder pipe with a teflon-plastic sleeve; the sleeve was pushed way up out of the pump body; the purpose of the sleeve is to make a "pinch seal" between the pump and copper tube). I RTV'd the sleeve in place, replaced the thermostat and the motor runs much cooler now, and there is a "sputtering" spray of cooling water out the two rear holes, as it should be.
Steve135
Chinewalker I am with you also on this Johnson made a 60hp in 1982 but not a 65hp??<br />steve
