1982 Johnson 140 won't turn over?
Krunchov
She tried to leave us out on the lake. Turn key to start and nothing. I was able to jump across the solonoid and get the starter to spin.
So there is no voltage on the S terminal of the solonoid in start but there are 12 volts on the S terminal of the ignition switch in start.
Oddly I can't get the solonoid to jump off by energizing the S terminal.
Perhaps the safety lock?
jakedaawg
Bad neutral safety switch or bad solenoid. Make sure you are in neutral. Using a remote start switch place one lead on the yellow w/ red stripe small terminal of solenoid, place other lead at battery positive on on the big terminal of solenoid. If engine cranks solenoid and starter are fine and you need to test neutral safety switch. If engine does not crank starter solenoid is bad.
To test neutral safety switch you need to isolate the switch in the remote control and use a multimeter to check for continuity.
Krunchov
The remote start switch is my next tool purchase.
I think the NS switch is in the throttle assembly, right?
emdsapmgr
Before you tear into the control box, you might want to consider replacing the start solenoid first. About $25. The internal solenoid contacts do get burned with age and may not always transfer current needed to crank the starter. If that's not the solution, then get into the box.
jakedaawg
Test the starter solenoid with a remote start switch first, as described above, it is the most likely culprit. I would guess you could get a switch for less than $10 at HF or somewhere.
Krunchov
Not the solonoid, not the ignition switch and if the two wires coming out of the remote unit are for the NS switch, and I'm pretty sure they are, it is not that either. So, this is a tiny wire off the switch. There are two relays ithe panel back by the engine. Is one of them for the starter?
Honorary Supreme Mariner
If there are 2 small square relays they are for the power trim system.---The red lead from the battery goes to one side of the starter solenoid.---I would take the starter motor apart for a " no money spent " inspection.--Very simple and easy to do.
Krunchov
