S M McInto
Thread starter- Joined
- Feb 27, 2012
- 42
Just got the boat a week or so ago, started it up on the earmuffs and started right up, ran for alittle while, shut off, started again, NO ISSUES.
Once I got it home I tinkered around with it a little starting it a few times on the earmuffs, no issues, although it does kind of sputter while idling, but I just associated this to being on the earmuffs.
First time in the water a few days ago I get it off the trailer, and it starts up we get a little away from the dock and idle and it cuts out. Now it doesn't want to start! It turns over a few times without starting, tried starting about 4 times, now after the 4th time I turn the key again and it doesn't turn over, try again same thing, then try again and it starts to turn over again and then finally started. Drive around for a little while and it was running good at all different speeds. we stopped and let it idle for about 10 minutes and it did fine, then it cut out. Once again after it cut out while idling, it took forever to get it started. Probably about 20-30 attempts, only about half of which were cranking..
I get it home and hook up the hose, starts right up, and idles pretty good, shut off, start again, NO ISSUES, besides idling just a little rough.
Second time out was yesterday on the water, pretty much identical to day one as far as starting issues. And again got it home and it started up perfectly out of the water.
I ordered carb rebuild kits already, but am not sure if this will actually solve any issues. The plugs look a little old so they will probably need replaced as well, but couldn't find which size to get online.
Any help would be appreciated, if you need pictures I can post them as well.
