1982 Evinrude 60 hp Tilt and Trim motor....
TampaNate77
Re: 1982 Evinrude 60 hp Tilt and Trim motor....
shouldnt the tilt pin stop the motor from doing that?
mark1961
Ensign
Is there a mechanism to lock the motor to the tilt pin?
TampaNate77
There are outboards that came without tilt and trim option..... wouldnt it be the same thing?
If you can lift it all the way up without it installed.....unless there is a mechanism to manually lock the motor down, what is going to happen in the water in reverse when you apply power?
Think about it.....
TampaNate77
