1982 evinrude 115hp motor and tilt and trim problems
salty_dog
my 1982 evinrude 115hp is having problems coming back into nuteral when ever i go forward and try to come back it would stay in forward and the bimini control would be in nuteral the cables are working fine and they r basically brand new and the tilt and trim doesnt wanna work either the fuse in the box is fine i would make this knocking sound one way and it dosnt do aything thing the other
SparkieBoat
Re: 1982 evinrude 115hp motor and tilt and trim problems
check your shifter connections, sounds like you need to adjust your new cable, you do this by turning the black round plastic thingy that is near the end of your shifter cable on the motor side. as for your tilt and trim, check all electrical connections at the relays, you can try jumping the power wires to test and see if a relay is bad..also make sure your hydrolic fluid if full.
emdsapmgr
Your engine has the old style remote trim/tilt box under the boat spashwell. In the box is a fuse and a single solenoid. The solenoid is only activated when the switch is in the "up" position. When going down, all current just goes thru the control box trim switch. If it goes down, but not up- check the solenoid. Does the solenoid click when the switch is moved to the up position? There should be a trim box wiring diagram inside the box cover.
ezeke
Adjusting the shift cable can be done in the following manner, once the shift rod height is properly adjusted; see: http://forums.iboats.com/showthread.php?t=334462&highlight=shift+height
Remove the spark plugs.
The cable should be disconnected at the engine with the control in neutral.
Shift the motor using the shift lever at the engine from neutral to forward and check the propeller to determine that it is locked. Turning the flywheel clockwise should turn the propeller clockwise.
Shift the motor to reverse using the shift lever at the engine. Turning the flywheel clockwise should turn the propeller counter-clockwise.
Return the motor to neutral and assure that the propeller is turning freely.
Push the control handle fully forward and back to neutral and stop.
Without moving the shift lever, adjust the cable to the shift lever using the black cable trunnion so that the cable slips on easily and reconnect.
SparkieBoat
nice wording there Ezek.
salty_dog
Re: 1982 evinrude 115hp motor dosnt wanna start now
okay i fixed those 2 problems now it dosnt wanna start it cranks but it dosnt turn over at all i do have new spark plugs but i do have almost three months old gas is that bad
tashasdaddy
make sure you are getting spark on all 4 cylinders, could be as simple as controller not engaging neutral switch. if no spark, unplug the big red plug connection, jump starter solenoid and check spark.
salty_dog
Re: 1982 evinrude 115hp motor wont start
i have spark on all four cylinders and still dosnt wanna start i have started the motor before wich was last week and now it just dosnt wanna start
ezeke
Are you pushing the key in to activate the primer solenoid while cranking the engine?
coolguy147
how did the motor start before? easy start? idled good? wide open was easy? no bogging? any lean sneezes? kill switch lanyard connected?
salty_dog
every thing started fine but i did have problems with cables and tilt and trim but i fixed that ever since i fixed those problems it just didnt wanna start any more
ezeke
Be sure to use the primer solenoid and have the battery fully charged so that you can turn the necessary 300 RPM to fire the ignition system.
