Horacio1983
Thread starter- Joined
- Jun 29, 2011
- 3
I have a 1982 Bayliner Capri with a Volvo Penta. The motor is a 4 cyl AQ125. Im not sure if it is an "A" or "B". I believe the outdrive is a 270. I pulled the prop out yesterday because it was chewed up pretty bad. The part number that i was able to get off of it was 814634. When I looked it up it is a 14x21 prop. The part is discontinued so my question is. Does anybody know what prop that i can use to replace the old one??? If so can you help me with a part number or brand name? Also, I noticed that it takes a little while to plain with this size prop. After doing a little research it sounds like this size prop is probably not the best size to pull a tube. I was wondering if I went down to a pitch of 19 if I would see a increase in performance? Any suggestions would be appreciated. Thank you in advance for your help.
